跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
一加 一后置相机更换
你所需要的
  1. 一加 一后置相机更换, 移除后壳: 步骤 1 中的图像 1,3 一加 一后置相机更换, 移除后壳: 步骤 1 中的图像 2,3 一加 一后置相机更换, 移除后壳: 步骤 1 中的图像 3,3
    • 移除sim卡托
    • 使用塑料工具,小心将后壳与机身分离。 千万小心sim卡槽附近以及其他脆弱位置。
    • 您可能在开壳的时候遇到些阻力,因为有些卡扣藏在手机内部边缘位置。 别担心,移开一个卡扣然后按着一个方向绕圈就能打开后壳。
    • 从上到下从左到右逆时针顺时针,一旦绕了半圈就可以用手移除后壳。
    • 别急着现在就拆下电池,请按照我们后面的指导来进行操作。 不正确的操作可能会使电池受损。
    It doesn't mention you have to remove SIM tray first.
    pawel - 回复
    I used the #0 for the rear panel screws. The #00 is too small and will slip, stripping the screws if you're not extra careful.
    anonymous 2668 - 回复
    where can i buy the battery??
    Shaun Davis - 回复
    Has anyone answered this? I am looking too.
    Elie Daou -
    They sell it on here, although I found mine on eBay.
    Roger -
    Aliexpress for $9 (original)
    David van Ballegooijen -
    The last three hidden screws are a !&&* of a time consumer to remove. probably you would need only a certain type of tweezers - I got stuck at midway and now I cannot get go have my phone detect the sim card either probably because the six screws are removed. I can now turn the phone back on but with no service or wifi connections are detected. This phone is a disaster!
    Manan Shah - 回复
    Ivdid that too but son in law found I had reinstalled sim card in backwards or upside down.
    wildcat75666 -
    Where did you buy the micro USB piece? Thanks a lot!
    Davide Rota - 回复
    EBay. I bought new battery cause old ibe was dead would not charge. Just ordered new cables fit 9.00 something free shipping. Anyway hope this fixes problem cause new battery did not fix problems.
    wildcat75666 -
    I was able to open going from the microusb slot and working my way around. The corners are tough, though.
    Roger - 回复
    in my phone the battery was glued with double sided adhesive tape, only on the right side. I pried the left side up first, and carefully removed the battery. to lift the battery I used first used a suction cup(?) followed by a plectrum like tool to lift te battery, and keep it lifted
    Eelco Busch - 回复
    A word of caution: the back panel is harder to remove than you might think. Especially because you may be removing the *screen* by mistake. When you have a "grip" with the tool make sure the metallic border is not coming off with it, and when you have removed enough to be able to lift the panel, make sure it isn't attached by ribbons - in that case you've been removing the screen. A good idea is to gently press your finger nail against the weak plastic located between the back and the SIM slot, and going up and down and sideways until you hear a click. Then you can start from there with the opening tool. As recommended be very gentle around the SIM slot.
    Menahem Julien Raccah Lisei - 回复
    Where do I get the plastic opening tool?
    Julie Hejducek - 回复
  2. 一加 一后置相机更换, 移除主板保护壳: 步骤 2 中的图像 1,3 一加 一后置相机更换, 移除主板保护壳: 步骤 2 中的图像 2,3 一加 一后置相机更换, 移除主板保护壳: 步骤 2 中的图像 3,3
    • 使用镊子,移除塑料塞子。
    • 一旦隐藏的螺丝出现了之后,使用 PH #00 螺丝刀移除3个 3.175 mm的螺丝。
    • 使用 PH #00 螺丝刀移除剩余的6个3.175 螺丝。
    The plugs are annoying to open for the first time. They're shaped like little pegs, but I was able to poke at them with screwdrivers enough to open.
    Roger - 回复
    the best spot to start prying the cover open is at the cable outlet for the power/volume buttons (careful not to dameage the wires)
    Marius137 - 回复
    A needle works best to remove the plugs.
    Stan Barton - 回复
    I second this. I used a sewing pin and the plugs came out in no time!
    Liam Ong -
    Be careful not to displace the rear camera when replacing the motherboard cover.
    Liam Ong - 回复
    when I lifted the motherboard cover the battery cable stuck on it so that I lifted both, the plastic cover and the cable - step 4 below was not necessary to perform. Be careful!
    Rene Hommel - 回复
    anyone know what is the 6 orange screws in step 2 are called?
    e.g. M2 x 2
    I lost some screws.
    So where can I buy some replacement of these screws?
    Tyler Durden - 回复
  3. 一加 一后置相机更换: 步骤 3 中的图像 1,1
    • 使用塑料开启工具,温柔地撬动黑色盖子,从设备上移除。
    At the top right of your device you see a white dot. That white dot is the warranty sticker. You need to take off that sticker in order to get to the screw that lies underneath. Then unscrew that screw. Otherwise you will not be able to pry off this cover.
    Anke - 回复
  4. 一加 一后置相机更换, 移除电池: 步骤 4 中的图像 1,2 一加 一后置相机更换, 移除电池: 步骤 4 中的图像 2,2
    • 在我们取下主板盖后,我们注意到电池上连接着黑色的带状物并安装在逻辑板上。
    • 使用撬棒,小心地开始将电池从黑色带状物对面的一侧提起。 请注意,高档胶带将电池粘贴在其位置上,请保持谨慎和耐心进行此操作。
    • 这种电池没有被包裹在硬壳中,所以它是柔软和有韧性的。 拆卸期间必须小心,以免造成永久性损坏。
    This took a ton of force to remove from the adhesive!
    Also I was able to take off the cable before removing the battery.
    Roger - 回复
    Is it OK to use the battery if I bent it during removal? I had to 'iron' it flat, but I think it might still be useable...
    Henry Annand - 回复
    the best way to remove the battery is to lever the left side up from the bottom and remove it from the glue with an old credit card
    Marius137 - 回复
    Do this! it comes up very easily this way. All the adhesive is on the right side.
    Daniel ONeill -
    Great suggestion with a card to remove the battery!
    Jeff Mack -
    Thanks for this trick saved me a lot of time
    George P -
    I second Dangerous Picture's suggestion. I found it very helpful to remove the ribbon from the dock (it was easy to do) before trying to remove the battery.
    Stan Barton - 回复
    on my phone extensive use of glue was concentrated on just one side (right hand side). Not impossible to remove, little tricky
    Rene Hommel - 回复
    I mistakenly removed the battery with force, and the back peeled and brought out smoke, seemingly like it's gonna explode. Help !!!
    warys Moreno - 回复
  5. 一加 一后置相机更换, 移除电池排线: 步骤 5 中的图像 1,3 一加 一后置相机更换, 移除电池排线: 步骤 5 中的图像 2,3 一加 一后置相机更换, 移除电池排线: 步骤 5 中的图像 3,3
    • 一旦电池被取出来,我们就会使用一个黑色撬棒来撬开电池,并将电池连接线从其底座上卸下来。 成功!
    • 你可以把电池先拆下来,这样会容易些。
    For step 4, the connection to the battery should always be done as soon as possible so after removing the back plate to the board would be ideal.
    Otherwise, very thorough so far!
    Duc - 回复
    Thought I was going to snap my battery in half but patience and slight pressure did the trick.
    Also agreeing the battery should be disconnected as soon as possible.
    Rasmus Beck - 回复
    From where do I procure a new battery for it?????????
    Roderick Edric Chandra - 回复
    très bon tuto ,aucun problème si vous suivez la procédure ,bravo et merci
    antoine v - 回复
    There are several connectors to the motherboard. In the picture above, one connector above and, below the screw thread, three more connectors. Be careful to reconnect any connectors accidentally disconnected while disconnecting / removeing the battery. In my case the connector shown at the top of the row came unconnected.
    Jörg Thiesemann-Bihn - 回复
    salut, pour moi le connecteur à la nappe était collé au cache en plastique qui couvrait la carte mère … mais le reste s’est bien passé.
    Merci pour le tuto !
    Didaf Wazir - 回复
    Thanks Buddy, I replaced battery of my one plus one and when I switched it on, touch was not working. It was heart sinking panic moment...Then I came across https://forum.xda-developers.com/oneplus... post, simple trick of sliding piece of paper below battery solved and infact improved the touch response. Thanks !
    Radhakrishna Shetty - 回复
    Kifch nikmandha
    asadzoya388 - 回复
    When putting in the new battery, the battery ribbon cable did not line up with the dock on the motherboard, on the replacement battery I ordered from iFixIt. I was able to carefully peel back the foil covering ribbon cable, align the cable, then press the foil back in place. Now, everything seems to be working.
    I P - 回复
  6. 一加 一后置相机更换, 移除排线: 步骤 6 中的图像 1,3 一加 一后置相机更换, 移除排线: 步骤 6 中的图像 2,3 一加 一后置相机更换, 移除排线: 步骤 6 中的图像 3,3
    • 在移开电池后,使用撬棒来移除剩下的排线。
    • 请注意,有两个侧面排线,一个在音量上下和电源键附近 另一个在左侧电池仓位置。
    the digitizer ribbon connector has a small plastic piece that blocks the connector from being removed through the slit. make sure to remove it (simple push with an opening tool). then you can remove the connector/ribbon cable.
    Michael Jubran - 回复
    All the ribbons came off easily after I found them, save for the volume buttons. Iended up tearing the ribbon trying to maneuver it out with the motherboard itself. Do you guys have any tips for removing the volume control ribbons? They seem to be held down by tiny extrusions in the phone.
    Crazy Joe - 回复
    Use extreme caution with the side ribbons. I've just destroyed my Volume Buttons as I tried to get the ribbon off.
    adenoid2 - 回复
    Another method for the side ribbons (power/volume) is desoldering the connectors - since I couldn't find any promising way to detach the buttons without damage I took this route and had success. Also note that you do not need to remove the mainboard and cameras for replacing the screen - a slight tilt should be enough to access the top ribbon (which belongs to the display assembly and has to be removed) so the side ribbons can stay in place.
    Florian Knodt - 回复
    I removed the side ribbon for the volume buttons is really easy by using the plastic tool between the two volume buttons in direction from up (backside of the phone) to down (screen of the phone). Trying to remove it from the volume down direction end of the cable almost destroyed the volume down button, so don’t try it
    Hristo Kovachev - 回复
    I just had to replace my screen, I skipped the removal of the side ribons and that worked perfectly. So don’t consider this step as mandatory to a screen replacement.
    Erwan Velu - 回复
  7. 一加 一后置相机更换, 移除主板: 步骤 7 中的图像 1,3 一加 一后置相机更换, 移除主板: 步骤 7 中的图像 2,3 一加 一后置相机更换, 移除主板: 步骤 7 中的图像 3,3
    • 在移除排线后,再移除这颗螺丝后就会很容易的使用撬棒将主板移开。
    • 这个螺丝使用了不同尺寸的螺丝philips 00, 3.00 mm长。
    After removing the final screw that holds the motherboard in place, do not just lift away the motherboard. The antenna is fixed to the back of the motherboard in the bottom right corner. Lift the motherboard from the top, leaving the bottom part of the motherboard (the part that is nearest the battery) close to the phone body. The antenna is a black wire that runs from the motherboard around the right side of the battery recess. It is held to the back side of the motherboard by a small, round, brass-coloured connector. It can be unclipped from the motherboard using a small pair of tweezers.
    Blenk - 回复
    There is a little tape in the battery box keep the antenna in place.
    You can remove the tape and have a few centimeters of antenna free in case you accidentally disconnect it.
    It is !&&* of a fiddeling to connect it again but it is feasible
    Jan Seidel -
    The final screw is a Phillips 000
    Jan Seidel - 回复
    After my second assembly replacement I realised it is not necessary to completely remove the motherboard. Just lift it from the top enough to navigate the top ribbon on the assembly through the chassis and therefore avoid any possible damage to the power and volume flex.
    mlin75 - 回复
    I encountered some resistance when lifting up the motherboard (and putting it back in later), from the corner near the sim card slot. Either because of a manufacturing defect or the plastic deforming due to age, the side of the PCB was snagging against the chassis. Got it out eventually but you have to be careful.
    John Smith - 回复
  8. 一加 一后置相机更换, 移除后置摄像头: 步骤 8 中的图像 1,2 一加 一后置相机更换, 移除后置摄像头: 步骤 8 中的图像 2,2
    • 一旦主板被拆下后就可以很简单的使用镊子将后置摄像头拆下。
    you don't need to remove the front or rear camera - once the motherboard is free, nothing else has to be done to it.
    fudgyhoops1 - 回复
    The camera may fall off as the connector is pretty slack.
    You don't have to remove it but be careful not drop or lose it
    Jan Seidel - 回复
结论
要重新组装您的设备,请按照本指南的相反顺序进行操作。
5等其他人完成本指南。
由衷感谢以下译者:
en zh
88%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
Javier Cruz
于09/22/14注册
2,265 声望
创作了3篇指南
团队
USF Tampa, Team 3-3, Brown Fall 2014 USF Tampa, Team 3-3, Brown Fall 2014 的会员
USFT-BROWN-F14S3G3
3 名成员
创作了20篇指南
一条评论
Steps 3 to 6 I believe are unnecessary.
Liam Ong - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 7,315
