跳转到主内容
PlayStation 3 Power Supply Replacement
你所需要的
  1. PlayStation 3 Power Supply Replacement, Smart Plate: 步骤 1 中的图像 1,2 PlayStation 3 Power Supply Replacement, Smart Plate: 步骤 1 中的图像 2,2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Power Supply Replacement: 步骤 2 中的图像 1,1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Power Supply Replacement: 步骤 3 中的图像 1,3 PlayStation 3 Power Supply Replacement: 步骤 3 中的图像 2,3 PlayStation 3 Power Supply Replacement: 步骤 3 中的图像 3,3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Power Supply Replacement: 步骤 4 中的图像 1,1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Power Supply Replacement, Top Cover: 步骤 5 中的图像 1,1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Power Supply Replacement: 步骤 6 中的图像 1,1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Power Supply Replacement, Memory Card Reader: 步骤 7 中的图像 1,1
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  8. PlayStation 3 Power Supply Replacement: 步骤 8 中的图像 1,2 PlayStation 3 Power Supply Replacement: 步骤 8 中的图像 2,2
    • Lift the memory card reader out of the PS3 enough to access its cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the memory card reader from the PS3.
  9. PlayStation 3 Power Supply Replacement, Power Supply: 步骤 9 中的图像 1,1
    • Pull the DC-In cables toward the front of the PS3 to disconnect them from the power supply.
  10. PlayStation 3 Power Supply Replacement: 步骤 10 中的图像 1,1
    • Lift the AC-In cables slightly away from the rear cover for clearance to access the AC-In connector.
  11. PlayStation 3 Power Supply Replacement: 步骤 11 中的图像 1,1
    • While depressing its locking mechanism, pull the AC-In connector out of its socket on the power supply.
  12. PlayStation 3 Power Supply Replacement: 步骤 12 中的图像 1,1
    • Remove the five 9 mm Phillips screws securing the power supply to the chassis.
  13. PlayStation 3 Power Supply Replacement: 步骤 13 中的图像 1,1
    • Lift the power supply upward from its front edge to disconnect it from the posts attached to the logic board.
    • Remove the power supply.
结论
47等其他人完成本指南。
6条评论
This is for the 60gb version. As there is no card reader in the 80gb i replaced the power supply in and some of the psu screws were in a slightly different place. But a very good guide.
Craig Taylor - 回复
I have a Ps3 that was bought in America. The power supply is different to ours here in South Africa (Cape Town). A friend who gave me the Ps3 also had an external power supply built so that it can be used here. It's been working for years but now I have that green light thingy going. I've removed the disc that was in it and thought it may have been inserted incorrectly. Now that I have seen your tutorial I will definitely check if it's the power supply or mother board. Thank you.
patrickms - 回复
CAN I HAVE THE MANUAL MY RED LIGHT IS ON ALSO DIRECT ME TO A GOOD PLACE FOR REPAIRS IN ACCRA GHANA EMAIL honmante54@yahoo.com thank you
honmante54 - 回复
why do your consoles have this red light on why do something about it
honmante54 - 回复
I have a ps3 but it's the CECHL but it has no card
kajussls121 - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 79
过去 30 天: 349
总计 107,893
