1 示意图
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
型号:
GA7011C
Background and Identification
Makita is a Japanese power tool manufacturer that was founded in 1915. It is a leading brand of professional-grade tools. This company produces cordless tools, power tools, petrol equipment, and batteries. Their tools range from wrenches and drills to chainsaws, lawnmowers, and angle grinders. An angle grinder is a handheld power tool that uses a rotating abrasive disk to do cutting and polishing work on a surface. These tools are commonly found in machine shops, construction sites, or metalworking projects.
This specific model of angle grinder has a 7 inch diameter disk that rotates and cuts, and the tool is electrically powered and needs to be plugged in to work. It has a few notable features that are meant to improve the lifespan of the tool and the experience of the user. First, this grinder has a ‘soft start’ mechanism. Going more slowly from a standstill to the full rotating speed creates a smoother start up, which causes less stress on the gears in the tool and increases their lifespan. Another feature is the wheel guard, which covers part of the rotating disk that isn’t involved in cutting. The wheel guard can be adjusted without tools, which is more convenient for the user. Finally, this angle grinder uses automatic speed control that applies extra power when the disk encounters resistance. Keeping up the same speed when the disk is under a load helps prevent the grinder from moving too slowly, which could damage the machine. To safely use this power tool, the operator should carefully read and follow all instructions and safety warnings, which can be found in the owner’s manual.
Technical Specifications
- Wheel Diameter : 7"
- Overall Length : 17-7/8"
- Net Weight : 7.5 lbs.
- AMPS : 15
- Power Type : Corded
- No Load Speed : 6,000 RPM
- Spindle Type : 5/8" - 11 UNC
- Switch Type : Rear trigger handle
- Lock-On Switch : Yes
- Lock-Off Switch : Yes
- Variable speed dial : No
- Bind-Up Control : No
