1 示意图
文档
型号:
GA4030K
Background
The Makita GA4030K is a 4-inch angle grinder equipped with a 6 AMP motor, delivering 11,000 RPM, suitable for various grinding applications in industries such as masonry, welding, shipyards, automotive, stone/tile work, HVAC, electricians, and general contracting. The compact design and 2-1/4" diameter barrel grip offer user comfort. This grinder is appropriate for tasks such as cutting brick and masonry, ferrous metal, paint and rust removal, shipyard maintenance, heavy machinery, metal polishing, auto repair work, and limestone cutting. The GA4030K also includes labyrinth construction, zig-zag varnish, and thicker coil wires to enhance durability.
Technical Specifications
- Wheel Diameter: 4"
- AMPS: 6
- No Load Speed: 11,000 RPM
- Spindle Type: M10 x 1.25
- Lock-On Switch: Yes
- Switch Type: Body grip/slide
- Overall Length: 10-1/2"
- Net Weight: 3.7 lbs.
- Power Type: Corded
- Shipping Weight: 9.55 lbs.
- UPC Code: 088381-096874
