Bearings and Blade Shaft
4 示意图
Popular Forum Questions
提问这里还没有问题。成为第一个提问者吧!
工具
下列是修复此设备所需要的常见工具,但您可能不需要某些工具。
型号:
6232-00-01
Background and Identification
The Little Wonder Pro Edger model 6232-00-01 - Rev B is a walk-behind lawn edger with a Honda GX120 118cc gasoline-powered engine. The Rev A model is very similar in specifications but includes a Briggs Intek Series 550 gasoline-powered engine. A lawn edger is used to form distinct boundaries between areas of grass and other ground surfaces, such as driveways and sidewalks.
The 6232-00-01 - Rev B model can hold up to three quarts of fuel and weighs 69 pounds without fuel. The lawn edger includes four steel-hubbed 8-inch wheels. Users can adjust the edger’s tension and the cutting depth up to 4-inches. It includes a fixed cast iron cutter head. The edger also features anti-vibration handles. It has dual belts to provide extra power to the cutting blade and can cut up to 90 feet per minute.
The 6232-00-01 - Rev B model can be identified by the name “Little Wonder” and “Edger” in red capital letters on the vertical section of metal near the edger’s handles. It has a red motor cover and a red blade guard. The edger includes two wheels below the handles and two wheels at the front of the machine in a side-by-side orientation. The machine’s steel frame is painted white and its fuel tank is a light beige color.
Technical Specifications
Product Number: 6232-00-01
Engine: Honda GX120
Handles: Anti-Vibration Grips
Displacement: 118cc
Cast Iron Cutter Head: Fixed
Drive Belt: Dual Belts
Edging Depth: Up to 4 inches
Steel Hubbed 8” Wheels: 4
Weight (pounds): 69
Fuel Capacity: 3 quarts
Warranty: 1 Year Consumer/1 Year Commercial
