17 示意图
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
型号:
LFQ4515E
Background
The Lifan Pressure Washer LFQ4515E is a gas-powered machine designed to clean various outdoor surfaces such as driveways, vehicles, decks, and patios. It is produced by Lifan Power USA and falls under the category of medium-duty consumer grade pressure washers meant for residential use.
The LFQ4515E is equipped with a 420cc Lifan gasoline engine and an axial cam pump, which together produce a maximum of 3200 PSI of water pressure. It possesses a 25 ft high-pressure hose and a 48" lance for increased reach. The machine also includes a quick-connect nozzle system that allows for an easy transition between 0°, 15°, 25°, and 40° nozzles, enabling different spray patterns. The machine's portability is supported by its never-flat tires and built-in hose reel, while its durability is ensured by the welded steel frame and triplex plunger pump. It is designed for medium-duty residential cleaning tasks such as cleaning concrete surfaces, siding, decks, lawn equipment, vehicles, and more. Its adjustable pressure and nozzle patterns provide the user with the ability to customize the cleaning power according to the task at hand.
Technical Specifications
- Model Number: LFQ4515E
- Product Type: Pressure Washer
- Engine: 4-stroke overhead valve engine, 420cc
- Pressure: 3200 PSI max
- Flow rate: 2.5 GPM
- Power source: Gasoline
- Pump: Axial cam pump
- High pressure hose length: 25 ft
- Wand: 48" steel lance
- Nozzles: 0°, 15°, 25°, 40° quick connect nozzles
- Water intake: Garden hose connection
- Wheels: Never-flat tires
- Dimensions: 30" x 19" x 24"
- Weight: 102 lbs
Warranty
The Lifan LFQ4515E pressure washer is accompanied by a limited 2 year consumer warranty. This warranty is applicable from the date of purchase and covers any defects that arise due to faulty materials or workmanship. However, there are certain exclusions to this warranty. Items subject to normal wear and tear such as nozzles, seals, and filters are covered only for the first 90 days. Additionally, user maintenance requirements such as oil changes and winterization are not included within the warranty's scope. In the event of a defect or malfunction, the users can claim the warranty which also extends separately to the engine for 2 years, provided by Lifan Power USA.
