4 示意图
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
型号:
PC3-22324S
Background
Landa specializes in cleaning solutions, like pressure washers and detergents, for various industries, including the agriculture, mining and drilling, construction, and transportation industries. Landa pressure washers can be used to remove mud, mold, loose paint, etc. from a variety of surfaces like decks, fences, sidewalks, roofs, gutters, etc.
The Landa PC3-22324S - 1.107-019.0 (2006) pressure washer was released from Landa in 2006. It is designed for medium-duty cleaning projects, including concrete cleaning, surface prep, and deck restoration. The Landa PC3-22324S pressure washer is gas powered and designed to be as portable as possible. It should not be operated indoors. Instead, use the Landa PC3-22324S pressure washer in a well-ventilated, outdoor area. (Pressure washing the inside of your house would probably make more problems than it would solve, anyways.)
Landa also sells pressure washer accessories, including a rotary nozzle, jet surface cleaner, and hose reels.
Identification
The Landa PC3-22324S pressure washer includes a base that houses an engine and other internal components. This base attaches to wheels for easy job-to-job transport. The PC3-22324S is mostly black and silver in color.
Specifications
- Dimensions: 39 x 24 x 20 inches
- Weight: 73 pounds
- Pressure: 2000-2700 PSI
- Engine: 196cc Honda OHV Engine
- Included:
- Detergent quick-connect nozzles
- 50’ x 3/8'“ hose
- Trigger gun
- 36” lance
