6 示意图
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
型号:
G 2700 DH
Background
The Karcher Pressure Washer G 2700 DH is a gas-powered pressure washer. Manufactured by the German company Kärcher, it is designed for varied residential cleaning purposes. This machine is engineered for light-duty cleaning tasks, which ranges from cleaning home exteriors to washing vehicles.
The Pressure Washer G 2700 DH runs on a Honda GCV 190 gas engine, offering a power output of 2.7 kW. It can yield a maximum pressure of 2700 psi, and its water flow rate can reach up to 2.5 GPM. The machine comes with a 25-foot high-pressure hose and is fitted with a 0.5-gallon detergent tank. Weighing approximately 60 pounds, it is designed for portability and ease of use. The unit is also equipped with an integrated storage area for nozzles and other components. Its design includes a compact frame and an integrated grip for maneuverability. It's designed for residential use, including tasks such as cleaning siding, patios, decks, driveways, and cars. With the right maintenance, this pressure washer can provide long-lasting performance.
Technical Specifications
- Model Number: G 2700 DH
- Product Type: Gas-Powered Pressure Washer
- Engine: Honda GCV 190 gas engine, 190 cc
- Power: 2.7 kW
- Pressure: Maximum 2700 psi / Maximum 187 bar
- Water Flow Rate: Maximum 2.5 GPM
- High-Pressure Hose Length: 25 ft
- Detergent Tank: 0.5 gal
- Weight: 60 lbs
- Design: Compact, portable with a powder-coated steel frame and impact-resistant cover
- Additional Features: Integrated storage for nozzles and accessories, ergonomic spray gun, integrated grip and hose hook, control panel with emergency stop
Warranty
The Karcher Pressure Washer G 2700 DH comes with a limited warranty provided by Karcher when you purchase the product from an authorized dealer. The warranty coverage differs based on the parts of the pressure washer. Specifically, the pump is covered for a duration of 5 years, the engine has a 2-year warranty, and all other parts are covered under warranty for 1 year. The warranty is designed to cover the repair or replacement of parts that are found to be defective. However, it is important to note that items subject to normal wear and tear are not included in the warranty coverage.
