1 示意图
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
型号:
17D889
Background
The Graco Paint Sprayer 17D889 is a handheld corded airless paint sprayer. It is a part of a product series designed specifically for do-it-yourself home improvement projects. This device is powered by a corded electric source and weighs approximately 5 lbs. It is designed to handle a maximum pressure of 3000 PSI and has a flow rate of 0.35 gallons per minute. Additionally, it is equipped with a 25-foot hose.
The Graco Paint Sprayer 17D889 features adjustable pressure control, which allows users to modify the pressure to match the surface and paint material being used. It also has a variable speed trigger that provides control over the paint flow rate. The sprayer is compatible with FlexLiner paint bags, which are designed for quick changes of coating material. The package includes 2 paint tips, 2 stain tips, inlet filters, 4 FlexLiner bags, a pour spout, funnel, strainer, and lubricant. Despite its numerous features, the device maintains a lightweight and compact design, making it suitable for smaller projects such as painting furniture, railings, shutters, and crafts.
Technical Specifications
- Model Number: 17D889
- Product Type: Paint Sprayer
- Type: Handheld Corded Airless Sprayer
- Power Source: Corded Electric
- Weight: 5 lbs
- Maximum Pressure: 3000 PSI
- Flow Rate: 0.35 GPM
- Hose Length: 25 ft
Warranty
The Graco Paint Sprayer 17D889 comes with a warranty that lasts for a period of 1 year. This warranty covers any defects that may arise due to issues in the materials or workmanship of the product. However, the warranty does not extend to cover any damage that might be incurred due to improper use of the product or from general wear and tear. In order to claim the warranty, users should follow the operation and maintenance guidelines provided in the included manual.
