2 示意图
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
文档
型号:
580.76805
Background
The Craftsman Pressure Washer 580.768050 is a pressure washer cleaning system produced by GOLDSTAR for Sears. It utilizes a 7.8 horsepower Generac GN-220 engine, and it can generate up to 3000 PSI at a flow rate of 2.5 GPM.
This machine includes a variety of features such as a dial to adjust water pressure, a selector knob to switch between chemical tanks, and a quick connect system for spray tips. It comes with a 50 ft high pressure hose, three 1 gallon chemical tanks, and is built on a steel frame with 12" pneumatic tires. The engine is an air-cooled, overhead valve model with a recoil starter, which uses regular unleaded gasoline and SAE 30 oil. The pump is an axial cam direct drive unit with a thermal bypass valve. It has ceramic pistons and a brass head, and connects directly to the engine crankshaft.
Technical Specifications
- Model Number: 580.768050
- Product Type: Pressure Washer
- Engine: 7.8 HP Generac GN-220
- Pump Type: Axial cam direct drive pump
- Pressure Output: Up to 3000 PSI
- Flow Rate: 2.5 GPM
- High Pressure Hose Length: 50 ft
- Number of Chemical Tanks: 3
- Chemical Tank Capacity: 1 gallon each
- Fuel Tank Capacity: 1 gallon
- Weight: Approximately 80 lbs
- Frame Material: Powder coated steel
- Wheel Type: 12" pneumatic tires
- Accessories: Four quick connect spray nozzles (0°, 15°, 25°, 40°), Chemical injection spray nozzle, Dual lance wand, Nozzle cleaning kit, O-ring maintenance kit
Warranty
The Craftsman Pressure Washer 580.768050 comes with a limited warranty that covers a period of 2 years. This warranty covers parts and components of the pressure washer, including the pump. Furthermore, the Generac engine included in the pressure washer is also covered by a 2-year consumer warranty. The process to claim the warranty has not been specified in the given context. Usually, to claim a warranty, you should contact the manufacturer's customer service or the retailer where you purchased the product and provide proof of purchase. However, you should refer to the specific product documentation or the manufacturer's website for the exact warranty claim process for the Craftsman Pressure Washer 580.768050.
