1 示意图
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
文档
型号:
580.75263
Background
The Craftsman 580.752630 is a pressure washer that is gas-powered and manufactured by GOLDSTAR for Sears under the Craftsman Brand. The pressure washer has a maximum pressure of 3,000 PSI and a maximum flow rate of 2.7 GPM. It uses a 187cc Honda GCV190 engine, which has a bore of 2.7 inches and a stroke of 2.0 inches. The engine requires an NGK BPR6ES spark plug, with a gap of 0.028-0.031 in. The oil capacity is 18.56 fluid ounces and the fuel capacity is 0.25 gallons.
The Craftsman 580.752630 pressure washer has several features. It uses a nozzle system with five quick-connect nozzles for varied cleaning applications and a siphon system for applying detergent. The washer is equipped with a thermal relief system to prevent pump damage and includes a 25-foot high-pressure hose. The handle can be folded down for compact storage. To operate the washer, oil and fuel need to be added, the garden hose and high-pressure hose need to be connected, the desired nozzle selected, and the water supply turned on. The engine is then started and the spray gun trigger squeezed to operate. The washer requires regular maintenance, including checking and adding oil, cleaning debris and the pump screen, releasing pressure, and using a pump saver or antifreeze for winter storage.
Technical Specifications
- Model Number: 580.752630
- Product Type: Pressure Washer
- Maximum Outlet Pressure: 3,000 PSI
- Maximum Flow Rate: 2.7 GPM
- Detergent Mix: Use as directed
- Maximum Water Supply Temperature: 100°F
- Engine Type: 187cc Honda GCV190 engine
- Engine Bore: 2.7 in (69 mm)
- Engine Stroke: 2.0 in (50 mm)
- Spark Plug Type: NGK BPR6ES, gap 0.028-0.031 in (0.70-0.80 mm)
- Oil Capacity: 18.56 fl oz (0.55 L)
- Fuel Capacity: 0.25 gallons (0.93 L)
- Hose Length: 25 ft
- Storage: Fold-down handle for compact storage
Warranty
The Craftsman 580.752630 pressure washer comes with a 2-year limited warranty provided by Sears. This warranty covers any defects in materials or workmanship. However, it's important to note that the warranty does not extend to wear items or any damage resulting from improper use of the washer. In order to claim the warranty, customers should contact Sears directly and provide details about the issue they are encountering with the product. The process may require proof of purchase and specific information about the defect.
