2 示意图
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
文档
型号:
580.752521
Background
The Craftsman Pressure Washer 580.752521 is a gasoline-powered machine made by Craftsman. The device is capable of exerting a maximum outlet pressure of 2700 PSI and has a maximum flow rate of 2.3 GPM. It uses a siphon hose to mix detergent and the maximum inlet water temperature it can handle is 100°F. The engine model used in this washer is the Briggs & Stratton 675EX Series, a 4-stroke OHV single cylinder, air-cooled, gasoline engine with a displacement of 175cc.
This pressure washer is constructed with a steel frame and features a fold-down handle and accessory tray for compact storage. It comes with a 25 ft high-pressure hose and a detergent siphon tube for applying cleaning solutions. The device has 5 quick-connect nozzle tips (0°, 15°, 25°, 40°, soap) and onboard storage for the nozzles and accessories. The pump part of the washer is an axial cam pump with a thermal relief valve and a brass pump head. It incorporates an automatic cool-down system that cycles water to avoid overheating. The device is primarily designed for residential use for cleaning purposes, such as home siding, patios, decks, cars, trucks, RVs and more.
Technical Specifications
- Product Type: Pressure Washer
- Maximum Outlet Pressure: 2700 PSI
- Maximum Flow Rate: 2.3 GPM
- Detergent Mixing Method: Uses siphon hose
- Maximum Inlet Water Temperature: 100°F
- Engine Model: 4-stroke OHV single cylinder air-cooled gasoline engine
- Engine Displacement: 175cc
- Bore x Stroke: 65.6 mm x 51.8 mm
- Spark Plug Model: 692051
- Spark Plug Gap: 0.020 in (0.50 mm)
- Valve Clearance (Intake): 0.004-0.008 in (0.10-0.20 mm)
- Valve Clearance (Exhaust): 0.004-0.008 in (0.10-0.20 mm)
- Oil Capacity: 20 oz (0.6 L)
- Fuel Capacity: 1.6 quarts
- Fuel Type: Regular unleaded gasoline, 87 octane minimum
- Frame Material: Steel
- Handle Type: Fold-down handle
- High Pressure Hose Length: 25 ft
- Number of Nozzle Tips: 5 (0°, 15°, 25°, 40°, soap)
- Pump Type: Axial cam pump with thermal relief valve
- Pump Head Material: Brass
- Automatic Cool-Down System: Yes
- Spray Gun: Yes, with safety lock
- Nozzle Extension Wand: Yes
Warranty
The Craftsman Pressure Washer 580.752521 comes with a 2-year limited warranty. The details about what is covered by this warranty aren't explicitly mentioned in the provided information, so it's generally assumed to cover any manufacturing defects or failures under normal use conditions. However, it's advisable to check the specific terms and conditions of the warranty. To claim the warranty, one would typically need to contact Craftsman's customer service, providing proof of purchase and details about the issue. More specific instructions might be found in the product manual or on the Craftsman's website.
