2 示意图
热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
型号:
CAP1645-OF
Background
The Bostitch Air Compressor CAP1645-OF is a compact, oil-free air compressor with a 1.6 gallon tank capacity. Manufactured by Bostitch, a division of Stanley Black & Decker, it is designed primarily for finish nailing and trim applications. The compressor operates with a peak motor power of 2 HP, and a running power of 1.5 HP. It utilizes a 120V, 14A corded electric power source. The maximum pressure it can achieve is 150 PSI, with an air delivery rate of 3.3 CFM at 90 PSI. It has a noise level of 79 dB and weighs 24 lbs, with dimensions of 17 x 13 x 11 inches.
The CAP1645-OF features a pump that doesn't require oil, eliminating the need for maintenance related to oil changes. It has a roll cage-protected control panel with an LED power switch, and includes storage for tools and hoses, as well as a small pocket for parts and fittings. The power cord can be wrapped around the handle for convenience. Its primary use is to power tools like nail guns and staplers for tasks such as installing trim and molding, door and window casings, baseboards, and cabinetry. It can also be used in furniture assembly. The pump provides good quality air, suitable for spraying paints and stains. However, it is not designed for use with high demand tools like impact wrenches or sanders.
Technical Specifications
- Model Number: CAP1645-OF
- Product: Bostitch Air Compressor
- Product Type: Air Compressor
- Motor: 2 HP peak, 1.5 HP running
- Power Source: 120V, 14A corded electric
- Tank Capacity: 1.6 gallons
- Max Pressure: 150 PSI
- Air Delivery: 3.3 CFM @ 90 PSI
- Noise Level: 79 dB
- Weight: 24 lbs
- Dimensions: 17 x 13 x 11 inches
Warranty
The Bostitch Air Compressor CAP1645-OF comes with a 1-year limited warranty. This warranty covers any defects in the materials and workmanship of the product. However, it should be noted that the warranty does not cover normal wear and tear, or any damage or issues arising from improper use of the product. To claim the warranty, the usual process involves contacting the manufacturer or the authorized dealer, providing details of the product and the issue, and following their instructions which may include returning the product for inspection or repair.
