热门论坛问题
提问这里还没有问题。成为第一个提问者吧!
文档
Background and Identification
The 3800 MicroBlender Bird-Air Oxygen Blender is a high-flowing blender that features a two-port mixture of FiO2 and produces a flow range of 2-120 LPM. It is a lightweight device that is perfect for accurately mixing oxygen and medical-grade air. It is identified by catalog number 03800A.
The 3800 MicroBlender has two outlet ports that allow it to be used with ventilators and also work as a stand-alone device with CPAP masks, resuscitation bags, and nasal cannulas. It is primarily used by physicians in medical settings to aid in a means of air ventilation. In terms of repair, there is a product warning that states that the 3800 Microblender must be serviced or calibrated by a trained hospital biomedical technician.
The blender is a small grey device with prominent black writing with two silver outlet ports that extend from the bottom of the device. It has a functional turn knob on the front that allows the user to select the desired air output. The “Bird” brand logo is identifiable in that top left-hand corner of the device and is written in red lettering. The primary and auxiliary ports are also properly labeled and easily identified.
Technical Specifications
Dimensions: 3.5×3.4×3.6” (89x86x91 mm)
Weight: 2.75 lb (1.25 kg)
Sensor accuracy:± 3% O2
Supply pressure: 30 to 75 PSIG/2.1 to 5.3 kg/cm2
Alarm activation bypass: When supply pressures differ by 20 ± 2 PSI
Number of ports: Two
Overall flow range: 2 to 20 LPM
Bleed flow: 10 to 20 LPM when activated
source: https://iteleti.com/bird-3800-microblend...
Additional Information
Bird Air-Oxygen Blender Product Page
