跳转到主内容
Apple's line of PowerBook laptops was intended for the professional and power users. The PowerBook line includes the PowerBook 100, Duo, 500, and 5300 Series; the PowerBook 1400, 2400, 3400; the PowerBook G3, G4 Titanium, and G4 Aluminum.
1017 个问题 查看全部
How can I fix the keyboard connector on the circuit board?
I have a Powerbook G4 and when I took off the top cover the connector to the keyboard broke off from the circuit board. Is there any way of fixing this part or building a temporary connector?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
最有帮助的答案
I have done something very similar with an iBook G4 and the connectors are all surface-mounted. This means you can't solder it back on and it's virtually impossible to fix. That was with the power button, completely breaking the computer.
As for the keyboard, I don't think you'll get any connector back on the board due to the surface-mounting. I can't help you any more than to advise a USB Keyboard
这个答案有帮助吗?
得分 1
添加一条评论
solder the cable to the circuit board. use wires (stripped from a multi strand cable) to support - worked on C64's and such
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
alex von 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 2,547
