跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
问题已关闭
Sim tray and back glass don't fit after display replacing
Hi,
I broke the front glass so i replaced it with one bought on the internet. I followed ifixit's guide step by step and everything went ok, i also replaced the battery at the same time and that works great too apart from the sim tray which is stuck open. When i insert it with or without the sim card it doesn't fit perfectly and is about a millimeter out. The back glass too won't slide back and i think it's because the part over the sim tray is lifted a little bit too much. Does somebody know how could i fix it? I really don't know why everything's not in the right position because i followed perfectly the guide and every passage was ok.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You need to carefully reverse your steps and to reseat the Logic Board perfectly in it's correct place. The fact that the SIM Tray is not right tells you the Logic Board is not exactly as it must be. Go slow, a lot can be damaged if you are not careful. When done right everything goes back easily into it's proper location.
这个答案有帮助吗?
得分 0
添加一条评论
Take the screws on the dock cover out
and try again
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,325
