跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
Won't boot - at all
I have a MacBook Mid-2009 2.1 GHz.
I've tried booting (with power adapter connected) from the internal and a bootable external HD, also a Leopard DVD. In each case, the white light on front of case comes on, it hums a bit, a click or two, then nothing (but the light stays on). Never a startup chime, and the display remains black.
User reports that it worked fine until... it wouldn't start. I've removed the HD, put it in a Voyager enclosure and it mounts to another Mac no problem (but I haven't booted another machine from it). I suspect some sort of power issue, but basically don't know what to try next, and am looking for suggestions.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The number of, flashing lights/beeps can indicate potential problems, so can booting to the Hardware Test Disk. Pull all the RAM you should get RAM failure beeps... if you don't I'd think logic board issues. Also look at some of the Answers from the Tags on the right.
''If this answer was helpful please remember to return an mark it Accepted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David A 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 379
