跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1197 个问题 查看全部
bottom half of my iPhone won't work
I dropped my iPhone and now the bottom half won't work, but the top half will. What do i need to replace to fix it plz
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个回答
已选择的解决方案
If you mean it wont work because it does not respond to touch, it is most likely the digitizer. Depending on if you still have your 1 year warranty through apple active depends on how you should proceed.
If you do still have it active, bring it to apple, and they should replace it for free (if there is no sign of damage).
If you do not have your 1 year warranty active still, you should check ribbon 2 to make sure it is fully connected. If ribbons 1, 2, and 3 are all connected properly and it still does not work you will need to purchase a new digitizer.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jason 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 1
总计 2,895
