跳转到主内容
The Sony Ericsson Xperia Mini Pro SK17i comes with a 3'' screen, a slide-out keyboard and a replaceable battery. Released in August of 2011.
12 个问题 查看全部
Why is my LCD screen has stopped work?
The LCD screen has stopped work , but otherwise is good , like touch screen and all button, is that from LCD screen or flex cable ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
6条评论
When you say it stopped working, what does it do? It is possible that your LCD is not longer working but the digitizer is still okay. Give us more information so that a final determination can be made. Right now I would think that a LCD/Digitizer assembly replacement would be the way to start.
完成的
When I move the keyboard, the screen works sometimes specific and sometimes does not work
完成的
When you move the keyboard, it does become unresponsive, or you don't see your image?
完成的
right now, all time the screen become black like never connected with device.
完成的
Yes, My friend tell me may that the flex cable is damage
完成的
显示更多的1条评论
添加一条评论
2个答案
最有帮助的答案
I definitely would start fixing it by checking the connectors and the cables. Make sure they are all in good working order. If they are, replace the display assembly and re-evaluate.
这个答案有帮助吗?
得分 1
1条评论:
完成的
添加一条评论
flex cable on slider must be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tatwot 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,380
