跳转到主内容
One of the beige G3 series produced by Apple between 1997 and 1999.
2 个问题 查看全部
HD ata, pata, ide and ultra ata
Hi, I own a Power Mac G3 desktop beige and I've bought a new HD Western Digital 80GB WD800AAJB 7200 rpm 8MB Caviar Blue PATA. The Mac sees the HD as it complies with G3 limitations (no bigger than 120), mounts it, formats it, uses it, but just for "normal" use, I mean writing, reading files. But when I try to use it in HD recording mode, with Pro Tools, the drive seems to work, but when I play recorded files, they appear to be fitted of spikes, and I get a crackly sound, like the old dusty vinyl one. If you examine the waveform, made with a sine test, you can find many, many spikes everywhere.
Can I fix it? may be with a special drive? Or is it an insoluble problem?
The OS is 9.2
Thanks to everybody
massimiliano
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
The problem is new drives write too slow in "backwards compatible mode". This might be an option, but contact OWC to see if they have any other solutions or advice.
If this answer was helpful please remember to return an mark it Accepted.
这个答案有帮助吗?
得分 2
1条评论:
Thanks! I see the solution by OWC is not compatible with my jurassic Mac. but I'll investigate this way.
完成的
添加一条评论
添加你的答案
Massimiliano Giusti 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 451
