跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
One channel of output jack is not working.
Speakers are working fine. When i plug in a 4 pole mini-jack (like iPhone headphone or similar, the left channel either is completely gone or intermittent. When i plug in a standard stereo mini-jack (regardless wether headphones or jack to RCA cable) left side is missing completely or i get thge same signal as on the right channel aka it's mono). Has anyone experienced similar problems? I guess it's the jack connector but I'd like to be sure before i open or return the iMac as it's just 3 months old. Is it something that can be easily done (maybe loose solder joint etc...) If anyone has pictures of an open iMac same series with detail shot of the outputjack i'd be greatful. Any clues actually are welcome.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
exactly the same problem here, did you get round it?
完成的
If you want a work around purchase an external USB audio adaptor. USB audio is separate from analogue audio.
完成的
添加一条评论
2个答案
已选择的解决方案
I had to bring it to an Apple Service Center. They replaced the logic board under warranty...
这个答案有帮助吗?
得分 1
2条评论:
Great job, all you have left to do is to accept your own answer. Then everybody that looks for an answer to their problem, will know what works :-)
完成的
@oldturkey: thx for the info. I am still getting aquainted with the structure of posting here. A bit confusing...
完成的
添加一条评论
最有帮助的答案
You should not be making DIY repairs on a 3mo. old machine of any type or make (unless you knowingly damaged it). Contact Apple. Audio jacks are not easily repaired, computer solder is of a special type and requires special tools and skills so as not to destroy the logic boards.
If this answer was helpful please remember to return an mark it Accepted.
这个答案有帮助吗?
得分 1
2条评论:
In what way is computer solder different?
完成的
Traditional acid core solder is capable of corroding board traces, generally its too thick or large In working with computer electronics, choose rosin core solder with a thickness of 0.75 mm., A normal, low-cost soldering iron is far too hot for delicate electronic work, additionally you need a soldering tip on your iron no larger than the connection you're soldering (many common irons are far too large). I'm assuming you've soldered a lot before? If not then it's going to be difficult, even for someone that's done a lot of soldering before its easy to overheat adjacent components, burn the board or bridge traces.
完成的
添加一条评论
添加你的答案
Xaver von Treyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,413
