跳转到主内容
This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
314 个问题 查看全部
sodering a game slot
How detailed is the sodering when replacing the game slot? Anyone done it yet?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Hey Pam,
The feasibility of installing a new game slot really depends on how much soldering experience you have. The process requires desoldering then soldering 18 surface mount joints. As you can see in this guide, each of the solder pads are very close to each other, making it very possible to accidentally bridge two of the points. On the plus side, the new slot should be pretty easy to line up, as it sits nicely in its spot on the motherboard. This makes it easy to line up the metal contacts with the solder pads. Overall, if you are confident in your surface-mount soldering abilities, you should be able to do it. If you have never soldered before, this will be a pretty tough repair. If the device is beyond repair otherwise, though, it may be a good device to practice on!
For help with soldering, check out our soldering help guide. You can also use the first link provided to remove the motherboard, if you have not already.
Hope this helps! Good luck, and let us know how it goes!
Soldering图片
指南
如何焊接和拆焊
难度:
困难
Nintendo DS Lite Motherboard图片
指南
Nintendo DS Lite Motherboard Replacement
难度:
中等
25 minutes - 2 hours
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 703
