跳转到主内容
Starts up, then goes dark
my good old iMac G5 has developed a new problem. When turned on it starts up quite normally but after a short while, either towards the end of the boot process or even after login the screen suddenly goes dark. No way of reviving it except force shutdown and then boot new.
When used as external HD via Firewire target mode the disk is accessible without problems, even for extended periods of time.
My theory would be that either there's a problem with the GPU or with the PSU. Apple doesn't offer repair or spares for those legacy models anymore. So any ideas on how to find out what's causing the problem and repairing it would be great!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Could be other problems - try an external monitor if that works your GPU and PSU are ok. Might be an inverter board, backlight or cable.
If this answer was helpful please remember to mark it accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kurt J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 475
