跳转到主内容
加入维修社区 - 创建账户
Triumph Motor Company 是一家高产的英国汽车制造商,从 1923 年开始生产汽车,直至 1984 年该品牌停用。二战后被 Standard Motor Company 收购,它凭借其“TR”系列跑车而闻名于世,其中包括经典的 TR4、肌肉感十足的 TR6 和楔形外观的 TR7。
Triumph spitfire 1968, carberator syncing, and distributer rebuild.
Need to sync my twin side draft carbs and distributer shaft wobble, due to bad brngs in lower part of unit. Can't get low end idle or high end set to work together, one or the other, but not both, due to shaft wobble! Points can be set for one or the other!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
This should help: https://lemon-manuals.org.ua/Triumph/196.... Worn distributor shaft bearings probably need either new ones, drilling/reaming out to press fit bearings or machinist to solve bearing slop. Perhaps searching Triumph forums may reveal more info, parts sources, and owners sharing invaluable help.
由完成的
@charlesamos just to make sure, your Spitfire has the 1296cc (MK3) or the 1147cc (MK2) engine and the original twin SU HS2 carburetors?
由完成的
添加一条评论
1个答案
@charlesamos use the Triumph Shop Manual to work on your Spitfire. It is searchable, so it does allow you to find the instructions needed to work on your distributor drive gear, bushings etc. It also addresses the "tuning" of the SU carburettors in detail on page 89 in that manual.
Also check page 173 and more in the Triumph Spitfire MkI MkII Parts Manual. It should help to "Visualize" the distributor a bit better.
Distributor before carburetor :-)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charles Amos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 17
总计 53
