跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 个问题 查看全部
Interior of iMac Screen Dirty?
I seem to have a couple of gray spots/streaks on my screen that can not be cleaned off.. they seem like they are behind the glass and not electronic. Has this happened to anyone else?
Thanks, Spencer
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Sounds like someone has been in it. You'll need suction cups to remove the screen. You can get them here: Heavy-Duty Suction Cups (Pair)
Here's how to do it: 更换iMac(英特尔27寸 EMC 2309 和 2374版本 )的玻璃面板
这个答案有帮助吗?
得分 1
5条评论:
it can be done with another object too, two butter knives (One on each side) does the trick as well.
完成的
A butter knife on a 2k+ machine! Maybe after 10 years passes. There is an apple dealer up the st. They are going to hook me up.
The whole top of the monitor is getting a little splotchy. It was not like that when it arrived direct from the factory. Perhaps heat is causing something on the surface of the LED to discolor. It's actually on the LED screen and not the glass.
完成的
Entirely different scenario than dirty glass. Get it in and I would also pop for the three year Apple Care if problems arise this soon. It may be cheap at twice the price.
完成的
It's definitely some build up and not "in" the monitor. The screen displays perfectly. Thanks everyone.. Hopefully I get time to take this over today.
完成的
The modeling IS in the layers of the monitor... the apple dealer up the street took it apart and cleaned it all up to no avail.. then ordered a new screen. Thanks for the replies! Spencer
完成的
添加一条评论
It's a common iMac display problem - see http://discussions.apple.com/thread.jspa...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
smahar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 8,623
