跳转到主内容
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
Change phillips screw bolts pentabole
Hey guys! First, my English is not very good I am Spanish.
I have a MacBook Air mid 2011. It has a hardware problem. the lower case creaks to support my hands on the computer. It's annoying and Genius Bar not give me a solution of the problem.
The problem is this: http://www.youtube.com/watch?v=Nq6jEONFZ...
Buy your shop iFixit pentabole screwdriver for macbook air. And while the screws fix the solution is temporary and the crack resumes.
Do you think changing the Phillips screws 2010 model may fix the problem?
Compatible Macbook air screws 2010 in Lower case of the Macbook Air 2011?
The sell out?.
Thanks for reading.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Before you tighten the screw remove it completely and put a drop of Locktight™ on it. Torque on the case will losen any screw eventually, only using something like Locktight can reduce the time it takes for the screw to back out.
If this answer was helpful please remember to mark it accepted.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
christianrojomontero 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 558
