跳转到主内容
修复你的物品
维修的权力
配件 & 工具
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
3291 个问题 查看全部
CHANGING PARTS IN MY iPhone 4, Water Damage
OK so i have an iphone 4. 8 gig (2 weeks old) from rogers, in Canada.
My g/f dropped it in the toilet and it has water damage, it turns on for a second and says connect to iTunes.
So i did lots of research, took the phone completely apart, dry'd it out in rice for a couple days, put it all back together and turned it on, it started no problem, and even made a phone call!! i was so happy. the problem is the battery is bad because of the water and the phone heats up really bad. I'm pretty sure i need a new logic board and battery.
My question is:
1. Do i need a new logic/motherboard?
2. Can i use a 4s logic board/motherboard?
3. Can i turn my iphone 4 into a 4s by swapping necessary components? (camera, motherboard?)
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
任天堂 Switch 套装
快速恢复到游戏的状态
购买 Switch 套装
2个回答
已选择的解决方案
First and foremost, I can glean from your question that your unit is an iPhone 4, and not an iPhone 4S. However, you should give us the last four letters and numbers of the serial code.
1. No one can tell that for sure. The only way to know is changing the battery, booting up the unit and tell how it goes. You may also want to clean it more throughly with isopropylic alchol.
2. Not that I know. If you go through the iFixit site, you may see that several key parts of the iPhone 4, including the bezel mount and some of the assembly, are radically different, thus...
3. ... you can't "upgrade" your unit.
You could, however, if your current issues are "just" a really short battery life and your unit heating try to fix it by buying a new battery only, and ordering a new logic board only of other troubles arise.
It's a safe bet saying that the plunge in water shorted up the battery, and will account for a short battery life and the heating up device (the logic keeps trying to charge a broken down battery).
The rest... has to assessed later, or in a professional lab.
If you're handy enough to do it by yourself, the safest course of action is:
  1. Acquiring some isoprophylic alchol
  2. Dismantling your unit, cleaning up gently the logic board and pay attention to suspicious patches of rust and other water debris, scrubbing them really gently
  3. Let the alchol dry: it dries much faster than water, that's why it has to be used
  4. Replace the battery
  5. Close the device, reassess the damages
  6. Eventually, report here how your iPhone is holding up
这个答案有帮助吗?
得分 2
添加一条评论
Can i replace a iphone 4s mother board with an iphone 4?
这个答案有帮助吗?
得分 0
评论:
No. iPhone 4 and 4S are not compatible.
完成的
Okay so if i change my mother board to a new mother board would it be a new set up of icloud??because my old icloud is lock i cant download anything
完成的
添加一条评论
添加你的答案
Jordan 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 6,707
