跳转到主内容
The first generation Honda CRV, produced from 1995 to 2001.
95 个问题 查看全部
won't start interior has no power
the interior has no power and won't start, the battery and starter are good,
there are two wires on the fuse panel under the hood when I put a jumper between them, it starts then I remove the jumper it remains running
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
I found it, it was the 100amp fuse under the hood
这个答案有帮助吗?
得分 1
1条评论:
What went wrong that caused a 100 amp fuse to go bad?
完成的
添加一条评论
Have you checked the fuses inside the vechile, mainly the one for the ignition switch.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andre 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,535
