跳转到主内容
型号A1288,闪存容量:8、16及32GB
451 个问题 查看全部
wi-fi having issues and not connecting
iPod keeps losing connection to the WiFi, even though other devices still are connected (in other words, it's not the router or modem). Sometimes it will still see the network but say it cannot connect, other times it cannot even see the network.
Is there a way to just replace the wireless chip on the iPod or does the entire motherboard have to be replaced?
Thanks,
peder
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
I don't know what Chip you guys think you can buy if it is a "Chip" as the wifi circuit is surface mounted to the main board. There is a separate wifi cable you can buy that has circuitry on one end but I do not think the cable can be installed without expensive surface mount equipment.
这个答案有帮助吗?
得分 1
添加一条评论
Are you sure it's a chip problem?
It could be the firmware, try restoring it and upgrading to the last version.
The problem started when you bought it?
这个答案有帮助吗?
得分 0
1条评论:
no it is out of warranty and i have tried restoring it. is there some kind of wireless chip/card in the iPod or is it all right on the motherboard?
完成的
添加一条评论
I'm having the same problem and i've restored the iPod three times. No matter what i do i can't fix it. I'm pretty sure i need the chip but i want confirmation before i take it apart.
这个答案有帮助吗?
得分 0
添加一条评论
Go under settings/general/reset/reset network settings. Sometimes that helps by clearing it and starting fresh. It will go to the apple then "restart" at which point try and connect again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iTronics Repair 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,373
