跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
1197 个问题 查看全部
screen raised, off center, logic board tilted, not snapped in.
I took apart my iPhone 3G and after putting it back together the screen assembly is uneven and will not snap in properly. The bottom right part of the screen is raised up and decreases in height (closer to being snapped in) towards the top. i can push down on it and it kind of bounces back to its 'uneven' position. if i push down the "plasma" in the screen gets distorted or white, like when you push on a computer screen.
when removing the front assembly the logic board seems to be tilted to the right a little bit. all the screws are screwed in, i dont understand why its not snapped in. it doesnt seem like anything is in the way of it.
any ideas?
EDIT: i figured it out, explanation too lengthy to type now. if anyone has same problem let me know and i would be glad to help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
评论:
I'm curious to hear what you did. My phone has a similar problem where one of the corners is raised.
完成的
Is it the bottom right corner? which corner? ill see if i can help
完成的
If you could post your solution for others to see, it would be great, thanks!
完成的
添加一条评论
1个回答
已选择的解决方案
you need to remove the motherboard and replace SIM end in first-the motherboard sits just under the lip of the SIM opening. it's a bit tricky and you may have to try a few times. it may be that you are caught up on the edge of the camera housing.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Eric Epstein 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 3,586
