跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南、拆解信息和故障排除信息,它是 DualShock 系列的继任者。可通过产品型号 CFI-ZCT1W 和主板型号 BDM-010 进行识别。
Should I even attempt this on my own?
Recently, my PS5 dualsense controller has begun succumbing to stick drift, making gaming increasingly aggravating. As I have already replaced the entire controller once before, I would prefer to not do that again and instead would like to attempt to replace the joysticks myself, preferably with TMR magnetic sticks to dissuade further drift in the future. However, I have no experience with or equipment for soldering, which is clearly a necessary skill to successfully replace these components. So my question becomes this: Should I even attempt to undertake this before finding some way to practice soldering independently beforehand, or should I instead try to find a local shop to perform the repair for me?
As a follow-up, since I intend to begin getting into soldering myself either way for future repairs, is there a good beginner/budget-friendly option for a soldering set? While I am sure the official Ifixit soldering set is of good quality, it is also more expensive to purchase the iron alone than it would be to simply buy a new PS5 controller. While I acknowledge that this would be an investment only made once to grant me access to a much wider range of repairs in the future, it does still somewhat defeat the goal of saving money by repairing over replacing, which is perhaps the most important factor in the current financial climate.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi!
If you do not have any experience related to soldering, I would not replace them.
They are difficult, even for people who have experience with it, because it's hard to get the solder off.
So, to answer this: I would get it to a local repair shop and let them do the repair. If you are not planning to solder in the future, I don't think it's necessary to buy a soldering iron.
You can either practice if you want to learn it, when you got enough experience (this will take time), then you can try to repair the controller.
To give you some insight: DualSense 摇杆更换
So for now, I would bring it to a local repair shop and ask them to do it.
If you have any further questions, please let us know :).
这个答案有帮助吗?
得分 2
2条评论:
It's not difficult for people with experience. I've changed all my controller sticks with no problems at all.
由完成的
Yeah it’s doable with the right tools. Still it requires some time and patience. It’s easy to overheat the board though..
由完成的
添加一条评论
添加你的答案
NBelladonna 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 28
总计 213
