跳转到主内容
加入维修社区 - 创建账户
广受欢迎的 Apple 迷你桌面电脑,2024款 Mac mini 的维修指南,拆解信息和疑难解答。该机型使用 M4 或 M4 Pro 处理器,最低配有 16GB 统一内存。
USB-C broken no connectivity on any usb-c port.
As per title. I've tried the various troubleshooting steps (holding the power button down to get to the boot select, however can't do anything as it won't recognise any keyboards/mice). I've tried multiple mice/keyboards and nothing works. It's like the ports aren't supplying power at all. It's been running happily for a while since I bought one when they came out (like within a week or 2 of launch so it's likely well out of warranty now). Are there any troubleshooting steps that I'm missing? I've tried to find support articles on this but they all refer to the SMC reset but that's irrelevant for this machine as they don't have it. There is no power draw on the usb-c (every single one) so I'm assuming it's a fuse that's gone somewhere? I want to exhaust all options before getting it under the microscope. It still boots but can't do anything with it, I'd happily use it as headless machine in my homelab even if the usb-c is toast. Is there a way to remote log in to the machine. It has RDP enabled but since power cycling it I can't seem to connect as it's waiting for a user to log in. This was the primary way I was interacting with the machine before the USB-C died anyway.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It's odd all the ports went on you. There are three elements to the Apple USB-C ports: Offering power, offering USB Data, or offering Thunderbolt Data. Each circuit is somewhat independent of the other.
If the mini's power output was the issue Other connected devices which have its own power source the lack of power from the mini shouldn't affect the ability to transfer data between.
Using a Bluetooth Keyboard/Mouse would be the simplest way around the issue. Otherwise, using a USB-C powered hub should be able to get around the power issue if that was the issue here. As an example UGREEN Powered 100W 10Gbps USB C Hub - 5 in 1 Adapter with 4 USB-C, 100W PD Ports for MacBook/Air, iPad Pro, iPhone
Lastly, here's a deep dive into the logic board if you are up to troubleshooting it Mac Mini (2024) Chip ID you still will need to find the schematics and board view drawings.
这个答案有帮助吗?
得分 0
2条评论:
I’ve tried with a powered hub as well as other devices that are self powered and nothing registers. It’s like all the usb-c ports are completely dead.
完成的
@chriscoope14215 - That points to a failed USB-C driver logic. It maybe cheaper to replace the logic board.
完成的
添加一条评论
添加你的答案
Chris Cooper 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 45
