跳转到主内容
加入维修社区 - 创建账户
一款由 vivo 制造的安卓智能手机。
My phone is charging very slowly and not showing its charging like 1po
Not charging
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
its possible that it can be the battery or the charging board that needs replacing.
这个答案有帮助吗?
得分 1
1条评论:
@schormn you are most likely right just add more detail to your answers. We found that people that come to iFixit are looking for complete solutions. They need more detaila to actually venture out to fix their devices.
由完成的
添加一条评论
@hemlattaparikh this could be an issue with the battery or the charging port. On your phone, go into settings and check the battery health. Let us know what it tells you. Also, check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out.
To work on your phone to replace the battery and the charging port, and since iFixit does not yet have a specific guide for that, use something like this video you do not need to replace the mainboard. Replacement batteries and charging boards are readily available at many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their phone.. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hemlatta Parikh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 112
