跳转到主内容
2.26 or 2.4 GHz / White plastic unibody enclosure
645 个问题 查看全部
问题已关闭
Mac won't power up after replacing upper case
I just followed the step by step instructions on replacing the upper case. After completing the project, the Mac won't power up. I understand that others have had the same problem. The Mac was working fine before except that I had to use a USB keyboard since liquid spilled on my keys. The USB keyboard overrode the normal keyboard so thats how I was able to get by.
When I attach the charger, the green light stays on instead of switching to orange to indicate charging. But even with the charger attached, it does not turn on.
In theory the computer should be working the same as before, except with a new functional keyboard right?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Remove the Bottom case then try to power up with power pads near by keyboard jack on the Logic board.
see the question for power pads :
Where on the logic board are the power-on pads?
这个答案有帮助吗?
得分 0
添加一条评论
Step #28 Upper Case Replacement Guide
You pinned the keyboard ribbon under the battery.
Remove battery, connect ribbon to Mother Board.
Use this opportunity to adjust the track pad "click" or lack there of by adjusting the T8 fat screw.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 947
