跳转到主内容
加入维修社区 - 创建账户
iPhone 17 Pro Max 的维修指南、拆解以及故障排除信息,该机型于 2025 年 9 月 9 日发布。
Back camera lens cover repair
I dropped my iPhone and one of the back camera lenses has cracked. I don’t seem to have issues with the camera performance but I worry this will get worse over time. I cannot seem to find any guide to replace the lenses anywhere, has this happened to anyone? I think I found some replacement lenses only but no instructions to install them. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
There are a couple of ways to replace just the glass lens that's cracked.
The first is how I've done it in the past, which is to pry out the old glass, clean the old adhesive, and glue on a new lens. The downside to this is that you have to be very careful to try and not get any glass or glue on the camera itself; you may even want to vacuum it out to make sure there aren't any glass shards left inside. With care, it's quite doable.
Since the lens is only glued in place, replacing it is the same process as it is for any other phone; here's a Google Pixel 2 guide showing how to replace just the glass.
Google Pixel 2 Rear Camera Lens Glass Replacement - iFixit Repair Guide
Now if you want to be absolutely sure to do it the "right" way, you would remove the rear camera assembly, then press the glass out from the inside. This completely eliminates any possibility of getting contamination in the camera or doing any damage to it. The downside, of course, is that it's a lot more work to disassemble the phone to get the cameras out. If you look at the last step of the iPhone 6 Camera Lens Replacement guide, you'll see how the official iFixit guys do it.
iPhone 6 Camera Lens Replacement - iFixit Repair Guide
If you decide to go that way, just follow the iPhone 17 Pro Max Rear Camera Assembly Replacement guide, then you'll be able to push the broken glass out from the rear.
iPhone 17 Pro Max Rear Camera Assembly Replacement - iFixit Repair Guide
iPhone 6 摄像头图片
指南
iPhone 6 摄像头更换
难度:
中等
15 - 30 minutes
Google Pixel 2 后置摄像头镜头玻璃图片
指南
Google Pixel 2 后置摄像头镜头玻璃更换
难度:
中等
2 hours
iPhone 17 Pro Max 后置摄像头组件图片
指南
iPhone 17 Pro Max 后置摄像头组件更换
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 1
1条评论:
just to add onto Jerry's answer, the antireflective(or whatever it is) coating on the camera lens itself is EXTREMELY fragile and easily damaged and will result in blurry images once scratched. Make sure you're using professional lens cleaning tools(there are ones with adhesive on the tip that cleans the camera and prevents damage to the lens) to clean out the glass shards and do NOT wipe it with ordinary fabric.
If you're worried about this also consider getting a cover for the lens cover, I believe there are ones sold that cover the lens completely with a slab of glass, which also works.
由完成的
添加一条评论
Hi, @franciscov44656 I gotchu.
This is pretty hard but safest way.. You must get the glass out by trying to break it more, then shake out all the shatters.
这个答案有帮助吗?
得分 0
2条评论:
Any guidance or tutorial to do this? Thank you!
由完成的
@franciscov44656
Afraid not but you can use stuff from other guides...
由完成的
添加一条评论
添加你的答案
Francisco Villegas Ruiz 将永远感激不已
浏览统计数据:
过去 24 小时: 22
过去 7 天: 170
过去 30 天: 839
总计 4,560
