跳转到主内容
加入维修社区 - 创建账户
The QSee QT5716-8G9-1 is a surveillance camera DVR, released in February 2014. It provides a surveillance system and records video from up to 16 cameras.
DVR Sound a Beep continuosly and don't boot up
When I switch on the DVR sound a beep continuosly and never stop, no leds and nothing on the monitor, the monitior is OK.
Do You know what to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@luismartin25097 what had you checked?
possible to open up the unit and take a photo ?
look out for any possible bloated capacitors.
完成的
添加一条评论
1个答案
Hi @luismartin25097
Disconnect the power to the device and open it up and check if there's a coin cell battery on the mainboard.
Like older computers, a lot of these devices had a coin cell battery to maintain the BIOS when the power is off (for whatever reason), and over time they fail, (non rechargeable) which can corrupt the BIOS preventing the device from starting.
If there is a battery, note its orientation i.e. +ve on top as shown on the battery, (this is so you reinsert it the correct way) then remove it and check its voltage.
If it needs replacing, before inserting the new battery, press and hold the device Power On button for 30 seconds then release it, reinsert the battery, (remember orientation) reconnect the power to the device and turn it on.
If it turns on most likely you will have to reset all the settings that you had before when you set it up, as the device has been reset back to its default state.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luis Martinez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 95
