跳转到主内容
加入维修社区 - 创建账户
This is an older family of Saeco devices. The main difference between Odea and Talea is the SBS brewing system of the Talea line. The model designation of the Odea is SUP031 **, the Talea SUP032 **.
Machine won't prime. How do you remove the water pump
I have the machine open but can't figure out how to remove the water pump
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@johngoncalves lets see if our coffeemaker Guru @vauweh has an answer for you.
完成的
添加一条评论
1个答案
最有帮助的答案
@johngoncalves Yes, unfortunately, the older Saeco models aren't as user-friendly as their modern Philips/Saeco successors. (0) Are you sure, the pump does not work? Did you check the if the water flows freely, especially the flowmeter? (1) There is a service-manual for you. Proof it using the testmode. (In German). (2) To expose the pump, you first need to pry off the white plastic elbow on the left side. Then pull the connection fitting on the left side of the pump out of the black rubber mount. Disconnect all electrical connections. The longer connector on the right side is screwed in. Use a 12 mm open-end wrench to unscrew it. Then pull the right connector out of the rubber mount, and the pump is free.
Tell us, if you had success. Take photos during the repair, maybe we can write a guide later.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
John Goncalves 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 48
