My iPad will have a white screen when it is cold.iPad屏幕白屏
我的iPad冷的时候屏幕会闪 严重点会白屏
The screen of my iPad will flash when it's cold, and the screen will be white when it's serious.
The screen has received a blow causing the screens back glass to become damaged where the metal oxide traces are located to send the electrical signals throughout the panel. From what I can see the side that is pulsating is likely when the panel was damaged.
This will require replacing the display assembly iPad Air 4/5 Screen and the iPad Air 4/5 Adhesive Strips following this guide iPad Air 4 屏幕更换
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 67
Can it be solved through repair without replacing the screen?
可以在不更换屏幕的情况下通过维修来解决吗?
由 刘叙玺 完成的
@l34enyry2ymihdx - Sorry, not possible.
To help you see the issue if you have an HDMI adapter to plug your iPad into a display you'll see the image is clean within it.
由 DanJ 完成的
@Danj It's normal when the screen is hot. I have a computer that can project the screen to see.
由 刘叙玺 完成的
@l34enyry2ymihdx - the micro fractures within the traces can heal when the display warms up and then pull apart when chilled. This is one of the symptoms which you are seeing.
Think it like taking a page of a news paper and ripping it up a bit trying to align the pieces back together so you can read/see the writing/picture. If you don't quite get the pieces to line up you may misread or not see the image clearly. This the same effect within the metal oxide traces not meeting up cleanly and at a distance when cold.
由 DanJ 完成的
Maybe you should visit an Apple Store to see what they say,
由 DanJ 完成的
