button to take picture not working.
everything works on my camera except the picture button that you push to process the pictures
Nicoli, the only way to determine what is going on, is by disassembling your camera.It is possible that it is the actual mechanical button that is not working, or the power switch block PCB that is not functioning. If you disassemble your camera, you could check the switch on the PCB with a multimeter. Check the guides on here to disassemble your camera. Hope this helps, good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 577
