跳转到主内容
修复你的物品
维修的权力
配件 & 工具
1.8GHz dual-core Intel Core i5 (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
365 个问题 查看全部
Spilt coke causing keys to become sticky
I accidentally spilt coke on the left side of my brand new macbook airs keyboard. Everything is fine but three or four keys on the keyboard where the coke spilt are sticking when i press them down. Any ideas on how to fix this?
已回答! View the answer 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
LCD iPhone 屏幕维修套装
预算选项,涵盖在我们的终身保修中。
购买套装
LCD iPhone 屏幕维修套装
削减维修成本,而不是质量。
购买套装
2个回答
已选择的解决方案
You could try something like Goof Off or Goo Gone on a cotton swab, but that's not going to get inside the upper case very well. Consider yourself lucky that you still have a functioning computer; I killed my old Dell with a glass of lemonade.
这个答案有帮助吗?
得分 0
评论:
i can lift the keys up but there isn't enough space to get a cotton swab under the key to clean it. Do you know how i can take the keys off, i've looked all over the internet but cant seem to find anything for this model of macbook air.
完成的
I addressed the same issue with a 13.3" 2012 MBA... and because I am cheap, I opted to pull and clean rather than replace (the keyboard/backlight). Soaked it in 90% isopropyl and cleaned in my ultrasonic cleaner with solution (not necessary in my opinion, but there are a lot of tight grooves and spaces in the keyboard). Let them dry off for a week, put it back, and it works great.
完成的
添加一条评论
Judging from the teardown of the 2012 macbook air (MBA), the schematics seem to be the same for the 2011 model. So if you wanted you could theoretically use guides for the 2011 model on your new 2012 MBA. You should double check just to make sure.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pgsaxa 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,956
