跳转到主内容
加入维修社区 - 创建账户
第六代 iPod classic 。机型型号 A1238,80/120/160 GB 机械硬盘,黑色或银色金属前面板。
iPod 6th gen won’t open
Hello! I’m currently trying to pry open my iPod. I have the tools with me, but it has been a difficult process, I’ve been trying since yesterday. I guess the right side and the bottom are good, but I’m struggling to get the left side. Any tips? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@ceciliaa_37 this model is a bear to open. You will find that most of the clips with be bend by the time you have it opened. I prefer a putty knife with a more rigid blade to loosen the clips for the cover. Review step 4 of the guide iPod Classic电池更换
"The theory behind this method is, rather than attempting to not bend the rear panel at all, to bend it in a favorable manner that allows you to easily restore it later."
完成的
添加一条评论
2个答案
最有帮助的答案
@ceciliaa_37 - It's not easy for sure! If we look at the top cover and how it's clipped on as you can see here in this image IPod Catch
We can see the catches along the sides the trick is to unlatch them on a side all together! This is where a a broad putty knife is needed as showin in the iPod Classic 前面板更换 guide in Step 4.
这个答案有帮助吗?
得分 1
添加一条评论
CAREFULLY slide one of those two tools in the first image as far as you can. Then try using the other to leverage the backplate off.
这个答案有帮助吗?
得分 0
1条评论:
You really don't want to insert the tools to deep here! That won't help you unclip the catch's on the sides.
完成的
添加一条评论
添加你的答案
Cecilia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 137
