跳转到主内容
Is it possible to take apart my power brick?
So, I believe my power supply is bad. I highly doubt Apple will replace it for free, so I want to know if it's possible for me to fix the brick. Has anyone ever taken apart one of Apple's power supplies? Do you have any pictures of the process?
Thanks!
Note to mods- would you rather I combine this with my question here? I'd be happy to do so if it would be better.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
The white Apple AC adapter is not easy to take apart. The two parts case are glued and you must work hard to separate them. Here's a link where you can see how it's done:
http://ultimatecarforum.com/smf/index.ph...
这个答案有帮助吗?
得分 4
2条评论:
Thanks for the link. It sure doesn't look like an easy process, but it's cheaper than forking over 80 bucks to Apple...
完成的
If the cable is damaged then yes you will probably salvage the adapter if you open it to make the repair but if the issue is a faulty electronic component then there's less hope to rescue it.
完成的
添加一条评论
添加你的答案
Josh Calvetti 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,607
