跳转到主内容
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 个问题 查看全部
What's the difference between AT&T and Verizon LCD/Screens?
What is the difference between Verizion and AT&T LCD Screens if I am planning on doing phone repair? I noticed that all the carriers have different screen assemblies for sale that specify the carriers name. Are the connections the same? And is this just a branding issue on the screen?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
The iPhone 4 ATT (GSM) and iPhone 4 Verizon & Sprint (CDMA) the only difference between the GSM and CDMA front screens is the placement of the mounting bracket screw tabs. Everything else is the same.
For iPhone 4 ATT get ATT or GSM Screen.
For iPhone 4 Verizon get Verizon or CDMA Screen, this will work for Sprint iPhone 4 also.
The Flex connectors are the same, only the screw tabs are in different locations.
这个答案有帮助吗?
得分 4
添加一条评论
Yea basically the frame on the outside of the glass n LCD screen. They line up different on the 4 CDMA, gsm and 4S
这个答案有帮助吗?
得分 0
添加一条评论
If your buying a replacement screen off ebay... make sure you buy the correct screen cause the tabs will not fit, period.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marc 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 23,078
