跳转到主内容
加入维修社区 - 创建账户
Morris Garages 是一家英国汽车品牌,由现已不复存在的 MG Car Company Limited(一家英国跑车制造商)注册。
Electric to coil and spark plugs
How do I test for electric to and through my coil
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
@peterdalby what make and model and year are we checking? What are the symptoms?
完成的
1976 MG midget. Car won’t start and I do have fuel.
If you have knowledge our experience on using a multimeter to test for electric current please give me a short but to the point description on what to test many thanks
完成的
@peterdalby do you have spark at the spark plugs when the engine turns over? A 1976, that would make it a MG Midget 1500. What country is it from. That model flopped in the USA due to new emission control standards.
完成的
Try checking for corrosion between the points in the distributor.
完成的
添加一条评论
1个答案
@peterdalby what make and model and year are we checking? What are the symptoms? Usually with the older cylindrical coils you just check the primary and secondary winding. For the primary winding you use a multimeter and set it to something like 200 ohms (depends on your meter of course) then measure the resistance between the positive and negative terminals of the coil. You should get anywhere between 2.6-4.0 ohms. For the secondary winding set your meter high, somewhere in the 20k ohms. Then measure the resistance between the negative terminal and the center terminal, where the thick coil wire (high tension wire) connects to. You should get a reading between 6-15kOhm If any of those values are off you have a faulty coil. See if this Checking Ignition Systems will help you out
这个答案有帮助吗?
得分 0
1条评论:
Many thanks I will do these tests my next time I visit to my garage. Thank you for giving me the pointers.
完成的
添加一条评论
添加你的答案
Peter Dalby 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 12
过去 30 天: 32
总计 217
