跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
问题已关闭
Xhanged batter. Me no soun, must talk on speaker. Camara doesnot work
Purchased replacement battery from you for my iPhone 3GS and replaced it per your instructions.
New npbattery works great....but I can't hear the people that calle unless I use the speaker ....and Camara a shutter does not open.
Can you pease help please.
Thank you,
Alex
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You may have damaged your camera ribbon, so you would need a new camera. Make sure it is connected securely, that could also be it as well. As for the ear speaker, check the #3 ribbon, if damaged you will not have functionality in the ear speaker. If you damaged the ribbon you can change it out. If it is the connector, then that would need to be desoldered and a new one soldered back on.
iPhone 3GS Proximity Sensor Ribbon Replacement
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 577
