跳转到主内容
加入维修社区 - 创建账户
丰田于 2001 年 9 月发布了 2002-2006 年款的 Camry XV30 系列,将其作为一款体型更大的轿车。
What are all the reasons why the engine overheats in a 2003 toyota cam
What are the all the reasons that the vehicle overheats in a toyota camry 2003?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@amachobria57095 that is a very generic question. Here are the most common causes for the overheating:
  • Low Coolant or Leaks
  • Stuck Thermostat
  • Failed Radiator Fan
  • Faulty Radiator Cap
  • Blocked Radiator
You will need to be a bit more specific with your question so we can narrow it down. It will help if you let us know what the exact issues with your Camry are. Also, let us know what you have already checked and what you have already tried to fix it. Let us now what engine size your Camry is.
这个答案有帮助吗?
得分 2
3条评论:
100% agree with @oldturkey03's assessment, but I might add one more; a blown head gasket can easily allow hot exhaust gasses into the cooling system causing it to get hotter than it normally would, leading to overheating.
Blocked or kinked radiator hoses can cause this too, but that's not a common problem.
完成的
Low engine .oil can also cause overheating of the engine.
There still may be enough oil so as to not cause an oil pressure warning though
完成的
Bad fan switch (sensor)
完成的
添加一条评论
添加你的答案
amachobrian648@gmail.com 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 93
