跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED Touch Bar)。
replacement battery not staying charged and fan running
Hi I replaced the battery, and it doesn't seem to be detecting it. If I unplug it from the wall it shuts down, also the fan is running and has not ever stopped. I have had it plugged in to the wall for several hours now
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
@kristinam66215 - Let's give this a try to see a bit deeper into the problem. Install this gem of an App CoconutBattery let's see what it tells us, take a snapshot of the Apps main window and post it here so we can see it as well.
完成的
添加一条评论
1个答案
if you see an 'X' or nothing at all where the battery icon is in the top menu bar this will confirm the battery is not being detected. In system profile under 'power' it should be displaying the battery info, same with CoconutBattery,. Carefully go over the battery replacement guide as it seems to be that the battery is not fully connected, this will cause the unit to go into a safe mode in which the fans will spin more to prevent overheating. Ensure that there are no bent or damaged pins and that the cables are fully inserted and latches are locked.
2017年款带功能键 的13寸 MacBook Pro 电池更换
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kristina M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 87
