跳转到主内容
加入维修社区 - 创建账户
2018 年 10 月 26 日发布。型号 A1984、A2105、A2106、A2108。提供 GSM 或 CDMA/eSIM、nano-SIM 或双卡版本 / 64、128 或 256 GB / 黑色、白色、蓝色、黄色、珊瑚色或红色。(读作“iPhone 10 R”。)
Réparer circuit de charge
mon iPhone ne charge pas convenablement
French->English translation:
Title: Repair charging circuit
Description: My iPhone is not charging properly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Repairing the actual charging circuits is extremely difficult, requiring board level repair and microsoldering skills. Why do you think the circuitry itself needs to be repaired? Frankly, it's much more likely that there's an issue with either the battery or the charging port, both of which are easier and cheaper to replace.
In lieu of a better description of the problem from you, I'd suggest you start with a new battery, then reevaluate if the problem is still there.
iPhone XR Battery Replacement - iFixit Repair Guide
If that doesn't resolve the issue, I'd replace the charging port. This guide shows you how.
Manuales / Apple iPhone XR / Flex with charging connector - Nadie Me Llama Gallina
Given more information, we may be able to give you a more precise solution. Does the phone indicate it's charging? Does the battery charge to 100%? What value does the battery health show? Does the battery drain quickly? Does it hold a charge? What exactly is it doing or not doing that makes you say it's not charging properly? The more you can tell us, the better chance we can figure out exactly what's going on with your phone.
English->French translation:
La réparation des circuits de charge est extrêmement difficile et nécessite des compétences en réparation de cartes électroniques et en microsoudure. Pourquoi pensez-vous que le circuit lui-même a besoin d'être réparé ? Franchement, il est beaucoup plus probable que le problème vienne de la batterie ou du port de charge, deux composants plus faciles et moins chers à remplacer.
En l'absence d'une description plus précise du problème, je vous suggère de commencer par remplacer la batterie, puis de vérifier si le problème persiste.
Remplacement de la batterie de l'iPhone XR - Guide de réparation iFixit
Si cela ne résout pas le problème, je vous conseille de remplacer le port de charge. Ce guide vous explique comment procéder.
Manuels / Apple iPhone XR / Connecteur de charge - Nadie Me Llama Gallina
Avec plus d'informations, nous pourrons peut-être vous proposer une solution plus précise. Le téléphone indique-t-il qu'il est en charge ? La batterie se charge-t-elle à 100 % ? Quel est l'état de santé de la batterie ? La batterie se décharge-t-elle rapidement ? Tient-elle la charge ? Que fait ou ne fait pas exactement votre téléphone qui vous fait dire qu'il ne charge pas correctement ? Plus vous nous donnerez d'informations, plus nous aurons de chances de comprendre précisément ce qui se passe avec votre téléphone.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Mahdi Kammoun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 111
