跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 个问题 查看全部
Replacement spring for pressurized portafilter
The pressurized portafilter that the Barista uses is supposedly not serviceable. But as the guide shows, you can certainly take it apart.
Has anyone replaced the springs inside the portafilter? If so, please share the specs on the springs and where you got them.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
The large round spring is Saeco part #126769918 and the smaller, elbow-shaped one is #126768418. Both can be purchased from http://www.saeco-accessories.com.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Take a look here and see if the mushroom spring is what you need: http://www.espressocare.com/Qstore/Qstor...
Is this it? http://espressocare.com/Qstore/Qstore.cg...
这个答案有帮助吗?
得分 2
1条评论:
That spring prevents the water from flowing out of the boiler until pressure reaches a certain level (at least that's my understanding). So it belongs to a different part of the machine.
With that said, it is possible that they use the same spring inside of the portafilter. Anyone know?
thanks!
完成的
添加一条评论
添加你的答案
Lawrence 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,852
