White Screen on power on
My Grandson dropped his Dell Inspiron pp41 laptop and now when he powers it on he only gets a white screen - sometimes with "static".
I wondering what the issue is and if its worth repairing.
Update
Well he tried a Dell recommended test as follows:
1. Remove the battery and disconnect the power cord (from the laptop! not the wall outlet).
2. Press power button for a few second.
3. Connect the power cord. Press the power button to start and then dock the battery.
And all he goy was a blank screen. Does not see any bios info or anything. See linked image.
http://www.flickr.com/photos/27763692@N0...
已回答! View the answer 我也有这个问题
这是一个好问题吗?
按维修分数 0
评论:
Any repair will most likely be cheaper than a new one :) All a matter of economics, and it keeps things out of the landfill.
Any additional thought?
Try my original answer.
添加一条评论
所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
浏览我们的商店
善于维修,即天赋异禀。
与 #ImAGenius 分享您的维修故事
我们都是天才
4个回答
已选择的解决方案
A white screen is usually indicative of a bad hard drive. Try disconnecting the drive and starting from your system installation disk to see if the issue persists.
这个答案有帮助吗?
按维修分数 2
添加一条评论
David Springett, I just looked at your picture and it looks like something different than the HDD. It looks to me like it is either the LCD itself or the inverter/ cable connection may be broken/loose. the first thing I would try is to attach an external monitor. This will give you an idea if it is the GPU on the logic board. If it works with an external monitor, it will be time to disassemble the laptop and look for loose connections or obvious broken parts. The service manual will show you how to work on the laptop, it is available right here. Hope this helps, good luck.
这个答案有帮助吗?
按维修分数 1
评论:
Thanks for the input. I'll have him connect and external monitor to check it out.
添加一条评论
motherboard, the video chip is not working replace it and it will fix ur issue
这个答案有帮助吗?
按维修分数 0
添加一条评论
Open the notebook and remove the BIOS battery. Wait a few minutes to BIOS reset e try again. If VGA or HDMI is normal, try replace the LCD mosfet (download schematic from your notebook). If 8 bips sounded, check LCD flat cable.
这个答案有帮助吗?
按维修分数 0
添加一条评论
添加你的答案
David Springett 将永远感激不已
浏览统计数据:
过去的24小时: 3
过去的7天: 24
过去的30天: 136
总计 14,667
